Client VPN and access to local LAN
Tonyis
Can you tell me if its possible create VPN for client via Meraki Dashboard on Meraki MX-88 with access to local network subnet? Because I need connect via VPN to NAS conneced to the local network. Can I change VPN subnet to same settings like LAN network ? Thanks for help.
"Client VPN users may access all subnets within the network by default. In order to control or restrict access for Client VPN users, firewall rules should be implemented."
https://documentation.meraki.com/MX-Z/Client_VPN/Restricting_Client_VPN_access_using_Layer_3_firewal...
2 REPLIES 2
ErnstTFD
"Client VPN users may access all subnets within the network by default."
How does this work? My VPN subnet is 192.168.5.0/24, I'm connected as 192.168.5.118. However I cannot connect to anything in my 192.168.1.0/24 subnet. For example if I ping 192.168.1.3, a NAS server, I get no response. If I put 192.168.1.3 in my file explorer, it fails to access the NAS drive.
What can I do to fix this?
