Access Point as reapeter
Kevin_Monsta
Just browsing
Hi, anybody know why AP can not stand alone as AP? i have 1 AP that connected as repeater even i have set the IP before. it connected to switch and not using power adaptor
7 Replies 7
RWelch
If the AP is configured with a static IP, it will advertise "ssid name-bad gateway" when the default gateway is unavailable. If it has no other APs to mesh with that provide a route to the Internet, the AP will remain offline.
If it does find another AP with a route to the Internet, it will act as a repeater but the Dashboard will report that it has an invalid IP configuration.
Gateway AP Switches to Repeater Mode
Kevin_Monsta
Just browsing
i cant open the link
RWelch
Try to re-open the link now.  Apparently there was an issue earlier where ever the documents reside.
[Service Notice] Documentation.meraki.com unavailable
It's very likely that this isn't connecting to the internet.
Can you verify the IP address configured on the dashboard when it's set up as a repeater?
Try performing a factory reset
Kevin_Monsta
Just browsing
we have set the IP, but we cant change the IP then. the IP not shown on dashboard.
this is new AP, should i do factory reset?
Try performing a factory reset please.
Ryan_Miles
Meraki Employee All-Star
If you connect a laptop to the switchport the AP is on does it get a DHCP IP (or does a static IP work)? That would at least confirm the switch is properly configured (carrying the mgmt VLAN for APs for example).
