2 years MR enterprise license
man1121
Just browsing
We have 2 Meraki MR42 and want to extend the licenses for 2 years, should I purchase 1 year enterprise license x 4?
MerakiDave
The licenses come in 1, 3, 5, 7 or 10-year terms.  You should simply purchase the 3-year license, because each 3-year license is the same exact cost as if you bought a 1-year license twice.  What I mean is, the longer the license term you purchase, the more discount is automatically factored in.  So if a 1-year AP license list price is $150, then the 3-year license is not triple that, it's actually double that, so $300 for 3 years, which would cost the same as if you purchased 2x1-year licenses.  When logged into your Meraki Dashboard, click into the search window and type "license calculator" and you can input your existing license info and try out different renewal options to see you new co-term date.
Also, the answer to the original question is no.  If you bought 4x1-year licenses, you would be licensed for 4 APs for 1 year.  That cannot be "rebalanced" over 2 APs for 2 years.
3 REPLIES 3
MerakiDave
Thank you.
Also, just to clarify, still purchase quantity 2 of the 3-year licenses for 2 APs.  Licenses are 1:1 with devices and are all inclusive licenses, so the license also includes 24x7x365 support, NBD hardware replacement, all firmware upgrades and even new features, and lifetime warranty on all indoor APs, switches, security appliances.
