How come I have to create two different entries for one network if I have multiple layer 3 devices?
Example: I have a Security Appliance and a Layer 3 Switch. I have to create one network for the Security Appliance, labeled NETWORK1-Security. The rest of the devices, Layer 3 Switches, Layer 2 Switches, AP's, are listed in a seperate network labeled NETWORK1-Internal? Can anybody explain this?
Solved! Go to Solution.
Before we combined one of our networks, the MX appliance was tracking clients by IP. When we went to combine the networks, this is the message we are getting:
"Security appliance networks tracking clients by IP addresses cannot be combined with other networks"
Also in the Address & VLANs section of the MX appliance, the option to track by IP if there is a Meraki layer 3 switch, is not available.
Why is this option, IP address, grayed out? If we track by MAC address the MX is only going to see the MAC address of the Layer 3 Switch.
You can't have two MX's in the same network (except for warm spare), but there's no restriction on mixing L3 switches and MX's that I'm aware of. I'm sure that I have a network with MX's and L3 switches in them.
I have networks with both L3 switches and MX devices in the same combined network. You should be able to have them all smushed together like that, so long as you've only got one MX (or MX HA pair) within the network. It's part of the full stack visibility goal.
When configured all together the MX saw all the traffic from the switch...do we not have something configured correctly
Ah. Well, there's your answer then. If I remember a support call correctly, then non-MX Meraki devices don't have the ability to track clients via IP. They can only track via mac.
Have you reviewed https://documentation.meraki.com/MX/Monitoring_and_Reporting/Client_Tracking_Options ?
Thanks everyone for the responses.
