vMX scale out
ByronZ
vMX scale out
We use MX64/67 in our branches, and they connect to our resources via AutoVPN to the vMX in Azure. Each branch has 2 ISP, configured as Active/Passive in the MX with AutoVPN.
The vMX in Azure has a maximum number of VPN of 250. We are sure to surpass this maximum number of tunnels in the coming months. Now it is time to think about how I can scale it out. I am not able to find any documents on this scenario.
Does anyone have any suggestions on how I can design it? Thanks
BZ
Inderdeep
@ByronZ : The "official" Meraki documentation says it can do 250 (but it is very conservative).  So if you feel you don't want to take on this small risk then you would need to get a pair of them, and put half the spokes on one and half on the other. Aaron also has a guide for doing this using templates.
https://www.willette.works/active-active-meraki-sd-wan-headends/
Check this post by @PhilipDAth
https://community.meraki.com/t5/Security-SD-WAN/vMX-on-Azure/td-p/49232
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
Inderdeep
ByronZ
Thanks Inderdeep for the quick response. Very nice article. Looks like it does support scaling out.
BZ
You could also get a single VMX Large if you want to keep the config simple.  Basically change no Meraki config, just the virtual appliance in Azure.  It is rated to 1,000 VPN tunnels.
https://meraki.cisco.com/product-collateral/mx-sizing-guide/?file
