Power supply for the MX64W-HW
Raelth
I'm looking for a replacement power supply for the MX64W-HW model. Does anyone know the exact specifications for the adapter’s plug tip? Not sure if it's 5.5mmx2.5mm or 5.5mmx2.1mm
Thanks for your help.
1 Reply 1
BlakeRichardson
If yours has simply failed and the device is licensed you should be able to RMA via support. If it's been damaged MA-PWR-30WAC is the part number and you should be able to order from your normal Meraki supplier.
