Cloud integration for Cisco Nexus C93180YC-FX3
JAH101
Hi all, i'm interested to know if there are any plans in Meraki Development team to integrate cloud monitoring/management of the Cisco C93180YC-FX3? (I can't see it on the currently supported models for cloud monitoring. Thank you!
JAH101
Thanks for the reply, yes I expected it would be completely different development line to get NX-OS integrated, it was just a question out of interest to see if it was on Meraki's radar or not, it was actually our CITO that had asked me on the subject originally (he loves the "single pane of glass" approach for management/monitoring etc).
Cheers!
Mloraditch
Nexus has not been actively discussed in any of the various conversations I've ever been part of. The goal is the entire Catalyst line and that timeline is still rather far out for completion. NX-OS would need completely new code to operate and require significant engineering effort.
Anything is possible, but I would not hold my hopes up. Your account rep may be able to tell you something more under NDA.
JAH101
Cheers!
JAH101
Thanks will take a look at that. 👍
