Cat9800 support for cloud monitoring
anto_franklin
Just browsing
hi Team,
we can see that  following cat9k PIDS are supported  for cloud monitoring . Is there any  recent changes in the list.  Does cat9800 device also supported for cloud monitoring ?
https://documentation.meraki.com/Cloud_Monitoring_for_Catalyst/Onboarding/Supported_Catalyst_9000_Se...)
10 Replies 10
DarrenOC
Hi @anto_franklin , the only supported catalysts are documented here
DarrenOC
Looks like I may have reposted the same link that you originally posted.  In short, the answer is no.
KarstenI
anto_franklin
Just browsing
Thanks for your response.  So the cat9800  is not supported for cloud monitoring on-borading in  to meraki  dashboard.  Is there any plan to support   PIDs other than Catalyst 9200, 9300, or 9500  ?
@anto_franklin Meraki are working on the functionality that is currently in a container on the switches, becoming part of the native IOS-XE.  I'm not expecting it this year, but hopefully next.  I wouldn't expect any other major improvements before then.  Of course I could be pleasantly surprised!
Hi Folks!  We are excited to be launching support for the C9800 HW models and access points inclusive of CW91XX, C91XX, 4800, 3800 & 2800 series at the very end of this month.  Documentation updates will be coming ~4/30 to reflect this.
Well that’s a bit sooner than next year! Excellent news!
Jenn_G
Just to follow up - we are officially launched to public beta availability.  Check out how to onboard here: https://documentation.meraki.com/Cloud_Monitoring_for_Catalyst
Emlu
Hello Jenn.
Any idea when 9800-cl will be supported? And when one of the supported ios-xe versions will be the recommended star version?
Jenn_G
Hi @Emlu
Regarding CL support -  in the works, top of the priority list for next WLC solution support.  Timing is not announced officially just yet.
17.12.3 (our launch release) is expected to achieve gold star within about one month+/-.
