Cisco GLC-SX-MM with Meraki MS225-24P switch
Ikea-STO169-LIT
Does anyone knows if I can use GLC-SX-MM SFP's with a Meraki MS225-24P switch?
DarrenOC
I’ve used a ton of them so you should be fine
Ikea-STO169-LIT
Thanks DarrenOC for the information.
IvanJukic
Meraki Employee All-Star
Hi @Ikea-STO169-LIT ,
As long as it meets the specs, it should be ok. Per the guide below.
"...we do not prevent third-party accessories from functioning, users should conduct their own tests to ensure proper compatibility"
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Small-Form_Factor_Plu...
Cheers,
Ivan Jukić,
Meraki APJC
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
