New VPN clients configured on a Windows 10 machine Windows 10 Professional, Version 21H2, are experiencing a problem with web browsing and traffic.
The connection to the VPN works normally. But then the web browsing stops working and the network behaves abnormally. Remote access to other sites also stops working.
As soon as the VPN is disconnected, the web connection is restored.
Currently, 2 VPN clients are experiencing this problem.
Both are recent PCs running Windows 10 and Windows 11 Pro X64.
As far as I know, all other VPN clients already configured and a bit older do not have this problem.
Thanks for your help.
Solved! Go to solution.
It's looks fine, so try to update Windows, otherwise try to open a case with Meraki support.
Are you using L2TP?
On VPN configuration > TCP/IPv4 > Advanced, disable default gateway to remote network or something like that:
Thank you for your answer. Yes I am using L2TP IPSEC protocol with preshared key.
I have disabled the default gateway as shown. This solves part of the problem with the VPV connection established, my internet connection is OK. But on the other hand access to my Lan and to remote VPN sites does not work. The ping on my remote application server gives nothing.
The VPN Client is being advertised on Auto VPN? If yes, It can be a Windows issue. Try to update Windows.
On auto VPN? What does it mean?
I don't understand.
How is your configuration?
Here are the VPN settings :
We are not in automatic.
Very good, thank you for your advice.
