MR74 Antennas
WaleedGalal
MR74 Antennas
Hi everyone
I just need to confirm if the MR74 comes with 2 antennas or no antennas at all and I need to order them separately?
Roska
Hello
Antennas are available as additional options starting: MA-ANT. Note that MA-ANT-20 is sold in sets of 2.
MA-ANT-20Meraki Dual-band Omni Antennas (!)
MA-ANT-21Meraki 5GHz Sector Antenna
MA-ANT-23Meraki 2.4GHz Sector Antenna
MA-ANT-25Meraki Dual Band Patch Antenna
MA-ANT-27Meraki Dual Band Sector Antenna
https://documentation.meraki.com/MR/Installation_Guides/MR74_Installation_Guide
5 Replies 5
Roska
Hello
jjlarsson
Will the MR76 need 2 sets of MA-ANT-20 so it will have 4 of them?
Bruce
@jjlarsson yes, you’re correct. If you’re using the MA-ANT-20 then you need to order 2x that SKU, so you have 4 antennas. Two on the top, two on the bottom of the AP.
WaleedGalal
Yes, it's the same as MR74
Ersin_Arslan
What are the Models of Outdoor Antennas?
MA-ANT-20 Meraki 4dBi/7dBi Dual-Band Omni Antennas, set of 2
MA-ANT-21 Meraki 5 GHz MIMO 13 dBi Sector Antenna
MA-ANT-23 Meraki 2.4 GHz MIMO 11dBi Sector Antenna
MA-ANT-25 Meraki Dual-Band 8dBi/6.5dBi Patch Antenna, set of 2 (if using with 4x4:4 APs)
MA-ANT-27 Meraki Dual-Band 9dBi/12dBi Sector Antenna, set of 2 (if using with 4x4:4 APs)
AIR-ANT2513P4M-N Cisco Aironet Four-Port Dual-Band Polarization-Diverse Array Antenna (Stadiums)
https://documentation.meraki.com/MR/Other_Topics/Frequently_Asked_Questions_regarding_Cisco_Meraki_A...
