Test Report for MG51-HW
ComplianceGEEK
Hi
Im having trouble locating the test report for the MG51-HW. Im also not able to locate the FCC number either?
5 Replies 5
rhbirkelund
For the specific FCC ID of MG51, you may need to open a ticket with Meraki Support.
But according to ChatGPT, it uses the FN980 chipset, which has the FCC ID RI7FN980.
ComplianceGEEK
Thanks where can i open a ticket directly with Meraki support? Yes i found the same thing with the FN980 chipset.
rhbirkelund
Either through a Dashboard Account, or https://meraki.cisco.com/meraki-support/open-a-support-case/
ComplianceGEEK
Thanks but meraki support would not help 😞
rhbirkelund
In that case I believe the last resort would be to reach out to your local Meraki AM/SE.
