We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
Hey,
is there an option to disable 5G and only use 4G.
I have a problem with one MG51 because the 5G connection is bad and i wanna use 4G only.
Max
Solved! Go to solution.
There is no option.
Okey, sad. Thanks
Get a 4G SIM from the provider, that might limit it?
Simple as getting a 4G only data plan...
