SKU for Additional MG51 Mounting Kits
sailorli96
For additional mounting kits for MG51 devices - would MA-ACC-MGKIT-1 provide additional mounting kits?
Or does that SKU only provide additional external antennas for the MG51E devices?
https://documentation.meraki.com/MG/MG_Datasheets/MG51%2F%2F51E_Technical_Specifications
Mloraditch
The description from the price list indicates it's an accessory kit.
The SKUs for additional antennas are different:
MA-ANT-C2-ADipole Antenna pair included with MG51E
MA-ANT-DUAL-C1Patch Antenna pair for MG51E
My suspicion based on the price and description is it's a full kit of the  normal accessories for the MG.
Hopefully someone knows for sure!
AlexCoste
Hi had the same question when I first saw this part MA-ACC-MGKIT-1.
Meraki Operations team has confirmed the following back in January:
'This part code should include all of the below
1. MA-ANT-C2-B – this is a set of 4 Antenna
2. Mounting Bracket – there are no customer facing part codes for the bracket
AlexCoste
Furthermore - because those antennas only fit the MG52/E, I'm assuming that the kit is only meant to be for that model. One thing I'm not sure about is if the mounting bracket for MG41/E, MG51/E and MG52/E is the same across all models. (not sure if someone can confirm)
To answer the original question, MA-ACC-MGKIT-1 doesn't include a different mounting compared to the one that comes in your box with MG52/E. It's a replacement in case you misplace the original one.
