New MG 3.212 beta firmware: MG51 upgrades and many MG21 fixes
Cellular gateway firmware versions MG 3.212 changelog
Important notices
  • For MG51/51E, Applying this firmware will upgrade the firmware of the Modem. This upgrade begins automatically after the MG has finished upgrading to MG 3.212. This upgrade will require 250 MB of data and up to 20 minutes (depending on bandwidth) to complete if uninterrupted. Please contact Meraki Support if you have any additional questions or require assistance.
Bug fixes
  • Corrected an issue for MG21 that resulted in the modems not defaulting to 1500 MTU when the network MTU was not specified
  • Enabled Cellular Modem upgrade for MG51/51E (See Important Notice)
  • Improved MG21 modem reliability to prevent them from getting stuck
  • Fixed a problem that resulted in MG21 IPv4 custom APNs not working properly
Known issues
  • MG Frequent Reboot under investigation
Now moved to stable
trh_jmperry
Are MX supposed to run MG firmware? My MX was showing update available so I scheduled them to run.
Then I notice they are running MG 3.102 and upgrading to MG 3.212?
RO
    This is not fixed.
    Must be upgraded to MG 3.212.1
    Also default APN works for telstra and other vendors.
    let's say OPTUS needs custom APN settings. Therefore, we must make sure it's upgraded to MG 3.212.1 and have the right APN settings.
@RO 3.213 is out, perhaps try that?
