MG 3.213 release candidate firmware: MG52 Telstra support and MG41 fix for CPU usage
Cellular gateway firmware versions MG 3.213 changelog
Important notices
  • Applying this firmware will upgrade the firmware of the Modems on MG51 and MG52. This upgrade begins automatically after the MG has finished upgrading to MG 3.213. This upgrade will require 250 MB of data and up to 20 minutes (depending on bandwidth) to complete if uninterrupted. Please contact Meraki Support if you have any additional questions or require assistance.
New feature highlights
  • {MG52} Enabled n48 bands for SA Mode
Supported products notice
  • {MG52} Modem firmware support for Telstra
Bug fixes
  • Fixed issue on MG52 where IMS is turned off for Verizon
  • MG-4700/MG-3059: Fixed an issue where MG41 would experience high CPU usage and packet loss until rebooted
  • MG-4692: Shortened the time the AutoAPN feature needs to cycle through APNs
1 Reply 1
Thanks for posting all of these updates @cmr .  It is a great service.
