-削除-
解決済み
a-ueno
-削除-
-削除-
1 件の受理された解決策
RWelch
Yes it is possible.
元の投稿で解決策を見る
2件の返信2
RWelch
Yes it is possible.
RWelch
Best Practices for Meraki Firmware
In the example you mentioned above, both are MX18.211 with one having a minor upgrade so they aren't too far off.  In general, you might test one location or separate test equipment for firmware releases then transition all sites once you have deemed them to work as expected.
