MX disconnects all VPN connections after changing things
Robin777
Hello all,
we have connected to one branch 10 IPSec connections.
After changing something in the Non meraki VPN config, ALL IPSec connections are disconnected.
I cannot understand this behaivor.... do you have the same problems?
Best regards
Robin
6 Replies 6
What change?
On some changes it resets wan interfaces (according to the documentation)
https://documentation.meraki.com/MX/Monitoring_and_Reporting/Appliance_Status/MX_Uplink_Settings#Sec...
Note: Modifying the following items will result in WAN interfaces being reset.
  • State (enabled/disabled) of any WAN interface
  • Addressing method (static/DHCP) of any WAN interface
  • State (enabled/disabled) of any LAN interface
This will result in a loss of connectivity on both Internet uplinks for up to 2 minutes. Therefore, it is recommended to only make changes during a planned maintenance window so that disruption is minimal. "
Robin777
Hello @ww ,
editing non Meraki VPN connections interrupts all non Meraki peers.
"Making changes to Non-Meraki VPN settings under Security & SD-WAN > Configure > Site-to-site VPN, might result in existing Non-Meraki VPN tunnels bouncing. We recommend that you make changes during a maintenance window to minimize the impact of Non-Meraki VPN tunnels bouncing. "
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-Site_VPN_Settings#Non-Meraki_VPN_Peers
AMP
Hello, Yes this is expected behavior. It is recommended to make changes to the Non Meraki peer settings during a change window
Knowledge is power
Robin777
@AMP Expected behavior or is not implemented as it could be?
Could this be a nice feature that will make less trouble meraki customers? 🙂
In the bottom right-hand corner of the dashboard is a button called "Give your feedback".  That is the best place to request new functionality.
