use an MX64w with an MX68
GH2023
Hi: I replaced my MX64W with an MX68 -  I need it more physical ports.
my question is: can I also use the old MX64W and use it as WiFi access point?
KarstenI
yes, but you have to put the device into a different Dashboard network. And the config will be a little bit strange as you need dashboard communication through the WAN-port and typically provide WLAN communication through the LAN-port.
You will need a license to activate the MX on the dashboard If you have already the license you can use it with no problem.
Not really.  It can't be in the same network as an MX68.
I guess you could create a seperate network and put the MX64W into that.  You would still need a licence for the MX64W.
