Nothing to do here as the config is assigned to the network and not the individually AP. Add the new one to the network and it will directly fetch the config. The old one can be removed.
What has to be applied additionally:
- IP-information if needed (for example if you use WPA-Enterprise).
- RF-Profiles
- Tags for the SSID availability
