change 802.1x with Radius to 802.1x with Local Auth
BPS
Set up a test SSID using Enterprise with Local Auth. Verified both the Meraki and Client certs are on the device but it still asks for credentials to log into the SSID. Not sure what I'm missing any ideas?
KarstenI
You have to tell the end device to use EAP-TLS. Otherwise, it will likely default to PEAP and continue with username/password.
BPS
I set up a GPO for computers and users to automatically request the cert, the end device is still asking for credentials. The device can connect to the SSID using 802.1X with RADIUS. Is there another setting with in Meraki that needs to be selected for this to work? Meraki2.PNG
KarstenI
You also have to configure the Supplicant:
https://aventistech.com/kb/deploy-wireless-network-with-group-policy/
BPS
Set that up today and it's still asking for credentials and not automatically connecting
