Wireless proactive pcap filtering options unclear
GIdenJoe
Hi all,
I have noticed that the proactive pcap section now allows you to select what types of events you can trigger the pcaps for.
However I'm not sure if it is a GUI limitation or an actual limitation.
According to the GUI setup I can only select one major category and then filter within the sub events of that category.
So let's say there are certain auth events AND assoc events I want to capture I get the idea that it is not possible.
The documentation does not mention the new selector options yet either.
Any thoughts?
1 Reply 1
I understand that this is a current limitation of the dashboard, not something documented, and it also seems to be a real system limitation, not just a user interface bug.
