Wireless Portal - Radius Auth - Change Splash "I forgot my password" link to custom URL?
TroyLowe
Just browsing
I have the splash page portal working with RADIUS authnetication fine, but I want to change the existing "I forgot my password" link to go to our service's reset page. I copied the Modern theme to customize it, but there isn't an obvious way to hide the current reset password link or change it to my own.
BrechtSchamp
It's embedded in the $MERAKI:MODERN_AUTH_ALREADY_HAVE_ACCOUNT_SIGN_IN_HERE_FORM$ token. But you won't be able to separate the forgot password link from "Sign in" button as that is in there too.
You can hide the link with CSS though:
#forgot_password {
  display: none;
9 Replies 9
Click on the pencil on the right hand side to be able to edit the raw pages.
TroyLowe
Just browsing
Yes I'm looking at the code, but there isn't anything that looks like the link. It is tokenized and I don't find these tokens in the documentation.  Which token represents the "I forgot my password" link so that I can remove it and put my own, while keeping the authentication functionality that does work?
I don't know.  Have you checked the other pages?
BrechtSchamp
#forgot_password {
  display: none;
TroyLowe
Just browsing
That's perfect, thank you!
secure-Ze8sU6z7
Sorry to bump such an old post, but I am trying to do the same thing and the above code is not working. I have tried editing the "auth.html" file and have tried putting the CSS above and below the $MERAKI:MODERN_AUTH_ALREADY_HAVE_ACCOUNT_SIGN_IN_HERE_FORM$ line as well as at the top and bottom of the file, and also the tried several places within "main.css" but still the forgot password link is shown. Does the CSS need to be added to a specific place or perhaps can this no longer be done?
TroyLowe
Just browsing
I placed it at the very end of main.css and it worked immediately.
Maybe try making a copy of a different theme and then editing that. I don't remember which theme I cloned.
secure-Ze8sU6z7
I took another look and figured it out. The name of the property has changed.
It is now:
#signin_form #forgot_password {
  display: none;
In my case, that was already in the CSS file but it said "display: inline" so I changed "inline" to "none" that worked!
GWVein64
I put it right after:
#forgot_password a:hover,
.form_links a:hover {
color: #0876BD;
Works like a charm! TNX!
