What is meaning on below error Meraki Error.
Rahul_Wankhade
Hi all,
What is meaning of below error. Is it critical to our wireless network or can be ignored.
Jan 24 16:21:46 10.138.80.46/10.138.80.46 cisco_meraki_wap|v1: 1611505325.032721513 AP01 airmarshal_events type=ssid_spoofing_detected ssid='Corp-SSID' vap='3' bssid='02:8D:DB: 71:C4:37' src='02:8D:DB:71:C4:37' dst='1A:BA:03:16:A7:5B' channel='11' rssi='7' fc_type='0' fc_subtype='5'
Regards,
Rahul Wankhade
CptnCrnch
Hi Rahul,
it looks like someone is spoofing / trying to impersonate your Corp-SSID.
For mitigation please take a look at https://documentation.meraki.com/MR/Monitoring_and_Reporting/Mitigating_a_Spoofed_AP
Rahul_Wankhade
Thank you for your response.
As I checked the Air marshal spoofs logs nothing showing there. Please refer below screenshot.
Regards,
Rahul Wankhade
Greenberet
check the selected time.
Currently you have set it to "for the last day", try a longer period
Rahul_Wankhade
Selected last week still not data showing.
Regards,
Rahul Wankhade
