Hi all,
I'm migrating customer's Aironet to Meraki. Existing Aironet WAP's are managed through WLC integrated on Cat3750G switch. Main SSID, let's call it "MyWifi" is secured via 802.1X and RADIUS (Microsoft NPS).
Since I'm really new to Meraki (and indeed on WiFi as a whole), I created a new SSID on the Meraki called "MyWifi2" to allow me to test things out before full rollout. I created a new policy on the Microsoft NPS server, replicating all the settings from "MyWifi" policy, except for Called-Station-ID. Since Meraki prepend BSSID in the Called-Station-ID, I used wildcard character: .*.MyWifi2$
In the backend, the Meraki WAP is connected to a stacked Cat 3650 via 802.1Q trunk, with the management VLAN configured as native VLAN. Meraki WAP mgmt IP is statically configured, allocated from mgmt VLAN subnet.
I used a customer SOE laptop to connect to the MyWifi2 SSID. At a glance, the laptop appeared to connect OK. I can browse the Internet. BUT, I could not connect to the Intranet. Fired up command prompt, and tried pinging the default gateway, received "Destination host unreachable".
I'm at a loss here. Any ideas?
