Using OTP for ssid authentication
Ran182
Hi, is it possible to configure the requirement for sms OTP or microsoft authenticator OTP in order to connect to a specific ssid?
I could not find any related documents, correct me if i'm wrong, in my understanding, it is currently not supported for Israel area?
2 Replies 2
KarstenI
You are probably talking about the splash page and not 802.1X? I am not aware of any restrictions, but if there are any based on your location, at least your own RADIUS-server can react in any way that you prefer.
Depending on your location, you can simply configure this in the Meraki portal for guest users.
https://documentation.meraki.com/MR/MR_Splash_Page/Splash_Page_Details_for_Meraki_MR#SMS_Splash_Page
If this is for a WPA2-Enterprise mode network - no one does this.  Every time you roam you would need to re-do your MFA.  It would be very annoying.
