Dear Community Members,
Due to an approaching certificate expiration, Meraki will be rotating the RADIUS certificate for Meraki Cloud Authentication on July 22, 2025.
Background:
Meraki Cloud Authentication is a feature used by Meraki wireless customers that allows for certificate-based authentication to an SSID in combination with Systems Manager (SM) or a third-party based MDM. This certificate rotation is a standard yearly action taken to maintain Meraki Authentication security. In some deployments, devices will automatically receive the new certificate, and no further action will be required. However, there are certain deployment scenarios that may require action to be taken.
Required customer action: Please review the deployment scenarios and next steps outlined in our documentation to determine if this certificate rotation will require you to accept the new certificate manually. If you need specific information about your impacted organization(s), please contact Meraki Technical Support.
Timing:
The certificate will be rotated on July 22, 2025. If your action is required, please take steps to renew your Meraki Cloud Authentication certificate as soon as possible.
Please refer to the FAQ for more details. If you need assistance or have additional questions, please reach out to Meraki Technical Support.
Best Regards,
Nithya Bandaru
Technical Marketing Engineer
Meraki Team
