Unable to proceed with to Connect to SSID with 2FA using Iphone/Ipad
MichaelLipat
Hi there,
We're using 2FA for our Authentication on Wireless which is from our Azure AD and sync on the Radius Server using Custom API.
I know this is a known issue with CNA of Apple when the authentication is using 2FA.
I have seen also some forum with Apple Discussion and raise with them but there is no resolution yet.
Here is the link: Captive Portal and Social Login MFA with … - Apple Community of the known issue.
Is there any adjustment can be done on Meraki Wireless Configuration to resolve this issue? Thank you.
1 Reply 1
I don't think so.  This is a 100% Apple issue.
Maybe try and encourage uses not to use SMS TXT for MFA, and try push notifications.
