Ubiquiti US-8-60W and CW9164i-MR - Unplanned low power mode
Anonymous
Not applicable
Hi folks,
I am playing a bit with a CW9164i-MR.
I use a Ubiquiti US-8-60W Switch. Connected to the switch is also a gen1 cloud key by ubiquiti currently drawing 2.5W
The CW9164i is also connected to the switch and i can see in the ubiquiti controller that it is drawing 12.7W with my phone connected to the 5ghz radio.
although LLDP-MED is enabled on the port the CW9164i is in "unplanned low power" mode. But why is that?
I used an old HP Switch before which worked perfectly fine. Also a Zyxel Switch seemed to work although it doesnt even support LLDP
1 Reply 1
Anonymous
Not applicable
solved.. the ubiquiti only supports 802.3af
my bad!
