Two Different Radius Server (No Failover) in the same SSID Control
AlexBecerra
I have a case where I have users in three different Radius servers, but all of them access the network through the same SSID, can I enable authentication via Radius?
I have only seen documentation that the option of more Raidus servers is used to fail over, what I am looking for is that if a user is not in radius 1, it is passed to radius 2 to search.
1 Reply 1
KarstenI
This has to be implemented on the RADIUS-server itself. If the user is not found, the server needs to go to the next server.
Or you just could clean up your RADIUS implementation ... 😉
