- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Tracking number of clients on specific SSID
Hey guys,
We are trying to figure out how many clients we have joining our guest network specifically across a specific timeframe, across all 1500 of our stores. I'm trying to figure out if there's a way to do that, even if it's through the API. Any ideas?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This will get you pretty close. Go:
Organisation/Summary Report
Make sure you are using the "new" version. There is usually an option to switch in the top right hand corner.
You can now generate a summary part for the "Entire Organisation" for a specific SSID for a summary time frame.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Perfect. That's exactly what I'm looking for.
Thank you!
@PhilipDAth wrote:This will get you pretty close. Go:
