Timebased tokens for guest SSID
naderelmansi
Hi
I Would like to know if Meraki AP has a guest SSID solution in built that provide automated timebased tokens for the guest
1 Reply 1
They have the billing solution.
https://documentation.meraki.com/MR/MR_Splash_Page/Billing_for_Wireless_Access
It's not automated but is a option. If it's doesn't make sense for you, maybe you should have to go with a third party solution like splash access or Cisco ISE.
