Static IP on Client IP
AdrienDumontet
I need sometimes to install my wireless ap on different places that require a static ip adress to connect to the web, but I cannot change the  IP that is assigned at first manually on 10.128.128.128, The thing I need to change is the "Client IP" thats is actually for example 10.68.254.81 to an adress like 192.168.151.5.
The only way I found for now is to use a utilitary that's called tftpd32 that simulate a dhcp server on a computer but that doesn't allways works.
My AP is a Meraki MR36 by the way
Could I get some help please ?
5 Replies 5
marce1000
 - In essence DHCP based  solutions are considered a must have standard for  wireless clients, get a robust DHCP server/service
 M.
AdrienDumontet
I know but I would like to do it in a different way that with DHCP because we cannot deploy DHCP on every site for some reasons.
marce1000
         >...because we cannot deploy DHCP on every site for some reasons.
 - In all honesty that is an outdated vision , and not applicable for modern business servicing ,
 M.
AdrienDumontet
I know but saying that doesn't help me right now to be honnest...
You can configure a static IP address using the local status page.
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
However if will be easier to use a temporary DHCP server (so the MR can connect to the Meraki cloud), and then change it to using a static IP address via the dashboard.
