Splash page not opening on clients with Windows 7
Tudor_Butiulca
Hello, I have configured a SSID with sign-on with my LDAP Server, we have like 5-6 laptops that still use Windows 7, when they connect to this SSID splash page is not opening by default, you have to open manually the default browser and only after that the splash page will load.
I have made a case but they told me if the splash page works with Windows 8.1 and Windows 10 is not a Meraki problem, I think is not faire this answer.
Also I have encountered the same problem with 2 clients using Windows 8.1
Does anyone have this problem also ?
1 Reply 1
Raj66
Hi @Tudor_Butiulca, So, the Meraki APs will only push the splash page to the client when they see HTTP traffic coming from the client device. It is possible that on windows 8.1 and windows 10, Microsoft has introduced a to send HTTP traffic by default to trigger the splash page which might be missing in Windows 7. A packet capture will confirm this behavior.
I did a bit more research and it seems like Windows does indeed check a Microsoft site for connectivity, using the Network Connectivity Status Indicator site (NCSI). There are a few variations of the connection checking process:
NCSI performs a DNS lookup on www.msftncsi.com, then requests http://www.msftncsi.com/ncsi.txt (HTTP file). This file is a plain-text file and contains only the text Microsoft NCSI.
I would recommend to take a packet capture and see if the NCSI packets are being sent by the windows 7 device and if so, we need to further investigate on the Meraki side. If the windows device is not sending those packets, we might want to check what service pack is being used and make sure it is up to date and check what is breaking it.
Cheers!
Raj
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
