Splash Login User Removal Permanently
SCNL
We have just configured the Splash Login via AD on particular SSID. Its working fine. But we are facing issues when we un-authorizing the particular user from SPLASH LOGIN entries. The unauthorize user state is showing inactive but the user still able to access the network. Could you please let us know any way to delete that user from entry table.
Ashish Dhillon
6 Replies 6
unfortunately It's not possible, but, you can block the client If you want. Just to understand, Are you using a external page? Are you blocking all access until sign-on on SSID configuration?
SCNL
Yes we want to block all access until for next sign on. But its not getting happened. User status is showing inactive but still user is able to access both internal as well as external network.
Ashish Dhillon
Are you blocking all access until sign-on on SSID configuration like this? Can you show me your SSID configuration?
  1. Log into Dashboard.
  2. Navigate to Configure>Access control or Wireless>Configure>Access control if in Combined view
  3. Select your SSID from the SSID drop down.
  4. Under the section Network access, locate the Splash Page section.
  5. Select the Click-through radio button. Once selected, captive portal selections will appear.
  6. Select your captive portal strength from the Captive portal strength drop down.
    • Allow non-HTTP traffic prior to sign-on: All traffic types except for TCP port 80 are allowed before the splash page is acknowledged.
    • Block all access until sign-on is complete All traffic types are blocked until the splash page is acknowledged.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Block_Listing_and_All...
SCNL
We already configured "Block all access until sign-on is complete" option. Below Elaborating the issue briefly :
- When user connects our SSID, user gets captive portal page automatically and able to login to the captive portal.
- Now the issue is : Post that when we unauthorize the user from SPLASH LOGIN, the user session showing as inactive. This means that now user must have to login the portal again. Right?
But this is not getting happened as user session is active. We checked it manually that user is still able to access the Network both internal as well as external. So, we want to delete the users session from the entry table. Please suggest.
I suggest you open a case with Meraki, It looks like a bug.
