Smart Home
Dutch9
Smart Home
I am having issues connecting my WEMO light switch to the wifi.  Are there settings I need to change in the MR33 to help connect these type of home devices.  I also have an Echo, seems to be ok for now.
What are the issues you are having?
MilesMeraki
There's no specific settings that need to be configured to allow the device to associate to the Meraki SSID. What are the problems you're having? Some more contexts around the issue/errors being presented would help us to help you.
fabian
do you use the access point in NAT mode? if your smart home is connected to a wired network and you are trying to access via wifi, there will be no connection because the access point is setting up a separate DHCP. To fix this, you can enable Bridge Mode or create a firewall rule. the bridge mode can be found under wireless / Access control /addressing and traffic
