- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Signal coverage on Meraki Dashboard
Hello guys!
Would it be possible to visualize the signal coverage of the Access Points when importing the customer's floor plan and positioning the Access Points on the Meraki Dashboard?
Thank you!
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The dashboard does not have a feature like this yet.
At this time you need to use an external site survey tool like Ekahau to visualize predictive or measured coverage using their measurement tool.
Cisco also has DNA Center where you can also visualize floorplans but that is only predictive modelling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Perfect, thank you so much for explanation!
