Setting up MR33 on a network with several AP
QueeSo
Hi, I am setting up an MR33 with PoE injector but I am finding it difficult to have my switch and APs link to the Meraki.
An idea of my setup is below:
-iDirect Modem for connection to VSat service
-MikroTik RouterBoard for DHCP setting
-I am trying to have the MR33 setup right between here to manage the APs, wired/wireless device (Users)???????
-Cisco Switch for connection other APs and wired/wireless devices on the network
If you want to manage a user's internet access using existing non Meraki APs you need an MX.  Current MXs are 64,67,68,84,100,250 and 450 in order of power from least to greatest.
The MR33 cannot manage the other APs, it talks to the Meraki cloud for management.  I'd just plug it into the Cisco switch.
QueeSo
Many thanks for the support. Is there any other meraki device I can use to manage the APs? I know the MR12 does but I couldn't find that model.
QueeSo
Thank you very much for helping out here. Much appreciated!
