We need a separate wireless network for AV equipment from our standard internal wifi. This separate network will contain a few devices that need internet access, but most clients on it will only need to see each other, not go out.
I have a single MR46 AP set up to broadcast an SSID specifically for this network but no clients can IP addresses from the AP. The AP is currently set in bridged mode and should be getting IPs from our local DHCP server, but that is not happening even though everything looks set from what I can tell.
(Another angle: when set in NAT mode, the Meraki APs automatically give out a 10 address. Is there a way we can possibly change the IP ranges that the Meraki AP gives to match the IP scheme of our AV network?
Thanks for any help you can provide.
