SSID Tunneling Supported Security and VLAN Tagging Methods
Andrew_Williams
Hi Team, does anyone have experience with SSID tunneling (MX as a concentrator). Wanted to know if the following security methods are supported:
  1. Enterprise Authentication with Radius Server (NPS) doing VLAN association
  2. IPSK without Radius doing VLAN tagging on a group policy?
Essentially looking to extend VLANs and IP addressing from the Head Office to a Branch Site
Ryan_Miles
Meraki Employee All-Star
Andrew I can answer the IPSK question. I just tested and the client does indeed honor the VLAN sent in the Group Policy when using IPSK. I would imagine a VLAN sent via RADIUS would also work fine.
10 Replies 10
Take a look at the documentation.
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/SSID_Tunneling_and_Layer_3_Roamin...
Andrew_Williams
Hi @alemabrahao  thanks for your help.
I have reviewed the documentation and I know it infers that Radius authentication works with VPN concentrator mode but I'd like to confirm with the experience of others that there are no issues with honoring the VLAN from the Radius server.
Additionally it doesn't mention IPSK without Radius and VLAN tagging through a group policy so I'm seeking clarification there as well.
You can perform a LAB to confirm. 😉
Andrew_Williams
If I had that option perhaps I wouldn't have posted on this forum asking for clarification 😉
Ryan_Miles
Andrew_Williams
FANTASTIC! Thanks Ryan! You're awesome and I really appreciate you testing it in such a short time.
Ryan_Miles
Just tested using JumpCloud RADIUS and the VLAN attribute is also honored/working.
Andrew_Williams
Thanks again Ryan.
Just to confirm, for the Client and VLAN settings on the SSID we're leaving the VLAN tag unselected right?
Ryan_Miles
In my lab the MX is concentrator mode. So not a interface dropdown, but rather an open field to type a non default/native VLAN ID. But I don't think the behavior would be any different.
In my usual setup I have the tunneled SSID drop clients into VLAN 600 (a DMZ subnet).
In my testing this morning I added VLAN 90 to the switchport connected to my MX. Then for the IPSK and RADIUS tests I set VLAN 90 as the VLAN tag (IPSK) /Tunnel-Private-Group-ID attribute (RADIUS). For the RADIUS config you of course need to enable the toggle for RADIUS override for the VLAN tagging to work.
Andrew_Williams
Perfect. Thanks Ryan you're a godsend!
