SCRIPT CREATION
Ciroski
SCRIPT CREATION
Hello good morning everyone
I am an admin user for the meraki console and my client asked me to create a script to block ip,
we currently have 400 active networks and making them once becomes complicated
is there the possibility to create a script for all the stores I have on the meraki console?
Thanks for the reply
Regards
Ciro Scalera
2 Replies 2
RomanMD
it is possible, of course. It is possible to create/update almost any settings from from dashboard, but this requires you to be familiar with some programming/scripting language.
Assuming that by "blocking IP" you mean that you want a L3 firewall rule or an inbound firewall rule, here are the Endpoint descriptions.
https://developer.cisco.com/meraki/api-v1/#!update-network-appliance-firewall-l-3-firewall-rules
https://developer.cisco.com/meraki/api-v1/#!update-network-appliance-firewall-inbound-firewall-rules
Ciroski
Thanks for the reply , after applying the correct parameters are you start the sciprt on the meraki console?
overwier? Inventory ?
