- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Remove clients from my wireless
In Meraki Devices I want to Remove all connected clients from my network and i want to forget the client my security key? Is that possible ?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
So there is nothing to do other than the suggestions, any change to the Template will affect all networks in the template.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for the response! I have different office with the same template-Dash Board ,but separate Network.Like Network-1,Network,Network-3 ...etc....the SSID Name is also the same.
I afraid that if I change SSID Password for Network-1 may change the whole office network. Hence,more unknown clients are connected into my Network-1 so I would remove all clients to forget the SSID Key with out change if possible
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You cannot force a client to forget the password, your only option is to change the password on the SSID itself.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Do you believe that if I change SSID password from different out off Network -1 from the same network organizations or Template ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If the network is not in a template, any changes will not affect the other networks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The network is in the same configurations Template but different Network
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
