Random blocked access of known devices
Tom_FF
It happens once ore twice a week a previously successful connected device receives a „The Administrator has prevented you from the network“ message and the policy in the WLAN Client overview changes from "Normal" to "Different by SSID".
It happens sometimes even to my own Admin MacBook when changing the faculty location resp. SSID even though I could connect successful there last time and therefore should be kind of a "known user" to this network.
What kind of effect is this and is there anything I can do to lower its sensitivity or switch it of completely? Is there a helpful document I should read?
Thanks in advance.
1 Reply 1
The Meraki system won't change the group policies in use on its own - so something is changing it.
Are you authenticating via WPA2-Enterprise mode, and are you pushing group policiesuser from the RADIUS server?
Are you using 802.1x switch port authentication?
