Question re: CW9166 dual radio operation
nneece
Question re: radio operation of CW9166. The CW9166 supports dual 5 GHz radios and this is reflected in the Meraki radio profile with Radio 1 being assigned 5-lo and Radio 2 being assigned 5-high as available channels. Question on 1 of 2 scenarios. If we disable Radio 2, will all of the 5 GHz UNII channels be available to assign to Radio 1 or will it still be limited to the 5-lo channels? Alternatively, if we assign Radio 2 to 6GHz operation, will all 5 GHz UNII channels be available to Radio 1?
1 Reply 1
Q1 - not sure, why would you do this, too much coverage in an area?
Q2 - yes all 5GHz channels are available on radio 1 if radio 2 is set to 6GHz.
