Problems of connection drops with Iphone13
YssyNocRedes
Hi, I did some research and found nothing.
I have the following problem only with the Iphone macOS 13.2.1 cell phone it connects to the Network
wifi and it doesn't stay long and it disconnects.
Android works perfectly.
Access point MR44 WIFI 6 Indoor
RADIO SETTINGS
2.4 GHz: 3 (20 MHz; 17 dBm)
5 GHz: 52 (80 MHz; 14 dBm)
dns
1.1.1.3
176,103,130,130
Check it out:
https://support.apple.com/en-is/HT202068
YssyNocRedes
Thanks, who do you think I have to check with Apple support?
No, but there is some recommendations that you can follow.
YssyNocRedes
ok, i'll try that.
