Prepaid access code
sdh1972
Prepaid access code
Is there a way to delete a batch of prepaid access codes?
Thank you,
Shar_De
BrechtSchamp
I don't think so. Maybe through Meraki helpdesk.
There is no easy way as @BrechtSchamp says.
I haven't tried this, but you might be able to invalidate all of the codes by disabling pre-paid access and then turning it on again.
You could also try changing the "cost" of a prepaid service invalidating all the existing issued PIN codes.
BrechtSchamp
@PhilipDAth wrote:
I haven't try this, but you might be able to invalidate all of the codes by disabling pre-paid access and then turning it on again.
Neither of those do the trick unfortunately.
