Playstations not working with splash Pages no redirect
Zakka
A few months ago, I started running into an issue where any PlayStations that try to connect to Wi-Fi are unable to get access. I have a splash page with an acknowledgement and due to this none of the PlayStations are able to connect to Wi-Fi, I have gone through some of the work arounds that I've found on the web but still for many PS5s those still haven't worked. Anyone has any suggestions?
It won't work with splash page, either you create an SSID with PSK or you do a bypass.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Blocking_and_Allowing...
PlayStations (especially PS5) do not use standard HTTP GET requests on port 80 to detect captive portals and as far as I remember, Meraki’s splash page redirection only works with HTTP traffic on port 80.
Brash
As said above, you have essentially two options:
 - Create a separate SSID for your Playstations that has no splash page
 - Manually configure the client to bypass the splash page
