Apr 25 2024
1:18 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Apr 25 2024
1:18 AM
POE Injector question
I have a site with 2 MR36H's + MA-INJ-4- Cisco injectors.
1 AP connects to a Meraki switch and is showing a 1gbps connection.
The other is connected to a Cisco C1000 with gig ports, but the AP is only showing 100mbps. We have changed out both cables.
Does anyone know if -
The injector sets the AP side port to match the AP connected
or
Does the injector get the port speed from the switch and set the AP port to the same
2 Replies 2
Apr 25 2024
2:17 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Apr 25 2024
2:17 AM
This power injector is gigabit, if you have already changed the cables, the power injector probably has a problem.
Have you tried with another power injector?
Apr 25 2024
2:19 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Apr 25 2024
2:19 AM
Thanks, I will arrange for the 2 injectors to be swapped around and see if the issue moves to the other AP
