- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Not Prompted for Password after enabling WPA2
We recently went from an open SSID to one using WPA2 PSK. Over the past few days we have had no reports of anyone being required to authenticate before accessing the network. Are the devices that were already connected exempt from this new password or is there something we may have missed to force all users to authenticate using the new passcode? Our goal was to require users to re-authenticate so we can better ensure that only those with the PSK are authorized to access the network. Thank you!
- Labels:
Installation
SSID
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Devices that are already connected won't be prompted for a password unless they disconnect and reconnect, as they have already authenticated (when the SSID was set to open).
Changing the access controls in the Meraki Dashboard doesn't automatically require every device to re-authenticate.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If you changed the password they need to edit the connexion and put the new password.
