New MR 31.1.1 beta firmware - AP auto placement, RADSec, more 6GHz support etc.
Wireless firmware versions MR 31.1.1 changelog
Important note
New feature
Bug fixes
  • General stability and performance improvements
  • Roaming-related issues with 802.11r configured SSID
  • In high-capacity wireless networks, APs may experience instability when the “Client Balancing” feature is enabled (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
Known issues
  • Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 5 Wave 2 and Wi-Fi 6 APs)
  • Clients may experience intermittent re-auth issues on MR45/55 APs
  • AFC not available on CW9163E APs
Other
  • This version and subsequent MR 31.x.x are only supported on 802.11ax (Wi-Fi 6) and newer MR models. 802.11ac Wave 2 and older products will not upgrade if they are in networks configured for MR 31.x.x versions, and thus, the new features will not be available. The bug fixes listed below will also not apply to Wi-Fi wave 2 and older MRs.
9 Replies 9
Somewhat confusing messaging about WiFi 5 wave 2 APs, are they supported or not...
IMPORTANT NOTE
  • Wi-Fi 5 Wave 2 MRs support
BUG FIXES
KNOWN ISSUES
OTHER
RaphaelL
okay , then what version will they be running ?  Older versions running MR30.X would have a notice like :
  • When configured for this version, MR12, MR16, MR18, MR24, MR26, MR32, MR34, MR62, MR66, and MR72 will run MR 26.8.3
I'm also confused
Ryan_Miles
Meraki Employee All-Star
From what I can tell in this current beta there's simply no build string for the older APs. So, upgrading a network should just not do anything to those older APs. Perhaps in future beta versions it will assign the most current supported version(s) as most firmware releases do as you mentioned.
RaphaelL
The notice was removed and it seems that Wave2 AP now have a 'backup' version of MR30.6 ( which makes sense )
However the bug fix and known issues still includes WiFi wave 2...  Time for a second attempt!
Ryan_Miles
Pretty sure nothing has changed. I still don't see build strings for any legacy platform. I also tested by setting a 28.5.1 network to r31 and the AP did nothing at all as expected.
RaphaelL
What will happen if I attempt to upgrade my firmware after the beta release of MR31.1.x, or if I have a scheduled upgrade?
After the beta release on May 21, 2024, the Firmware Upgrades page will let you set your network to MR31.1.x or newer. Affected devices will only upgrade to their latest supported version of MR30.x. The AP status page will correctly display the running MR30.x build. Documentation for the max-supported firmware will be updated to reflect the same.
https://documentation.meraki.com/MR/Other_Topics/Cisco_Meraki_MR_Firmware_Restrictions_Overview_and_...
Doesn't seem to be the case from what Ryan could test
AnythingHosted
The slow end of support for my MR33s, MR42s and MR52/3s ...
BHC_RESORTS
@Ryan_Miles is there any fix for the MR36H kernel panic bug in this release?
BHC Resorts IT Department
